Switching circuit - Switching between a bluetooth music module and a FM radio board.
Scaggsj
Joined May 7, 2020
I'm pretty sure this is a very simple circuit but I am having troubles figuring out the how. I'm new to circuitry so the explanation may not be technical.
I have two components I'm trying to switch between. One is a bluetooth music module and the other is a FM radio board. Ideally I would like to use a momentary type switch that latches where comp #1 is on with initial power and then a push changes to comp #2 and another push back to #1.
Scaggsj
Joined May 7, 2020
What are you connecting them to, an amplifier??
Both are independently amplified. The project is for my brother. I'm taking his old vw amfm radio and putting bluetooth in it. The old radio was inop and a new FM board was not to expensive. I have wired a potentiometer with on/off switch to control both volumes. I'm having trouble switching between the two outputs. I was trying to toggle between them with a momentary single throw but I'm lost at this point.
Thanks for replying, I really appreciate the help.
