Currently, I am working on designing a class D amp and started with the triangle wave generator.
I have built the following circuit:
Right now it seems to work and generates a decent triangle wave, but the problem is if I lower or increase the voltage the wave falls apart. Is that normal behaviour or could the circuit be improved? If so how, and why it is better that way.
Also, are these op-amps suited? I know these are high frequencies but these were the best I had around.
Thanks for your time.
