Hi from a new mamber. Retired, and now have time for a hobby.
first up, im looking to build a power supply. while I am comfortable following a schematic and know what the components are,
will it work or not is another issue. I found this schematic on line and would like to ask if it will work, or go pop?
If I remember right, this puppy is suposed to pump out 1.5 - 37 Volt at a max of 30 Amps. (Why not 0 - 37?)
Now I can understand the 6 x 317s for the heat dispersion, would it be any better to have say 8 x 317s
Also I would like to have the ability to adjustable current, would be greatful if anyone could assist me in this regard.
I also have a display to show volt and amp output.
I intend to have two or 3 outputs, each being adjustablein its own right, I do understand the total current can only be up to the maximum of the unit, 30 Amp in this case.
The transformer for this I pulled of an old microwave and rewound it, got a good output that tests as 12.8 volt, with another winding that gives 5 volt for a cooling fan.
Thanks in advanc
Thanks in advanc
