I'm sure I'm missing something very fundamental here, but I've built a boost circuit on a breadboard (see attached schematic) to convert 5v to 12v using an LM2577-adj. I want to power a 12v PC fan (rate at 12v at .06A) as the load.
The LM2577 seems to work fine, as I'm measuring 12v.
The fan doesn't run until I give is an initial spin then runs slow. Even though I get voltage reading of 12v without load, it drops to 5.66v with the fan load and draws 22.1mA.
When I connect the fan directly to a new 9v battery, it starts up on its own and runs strong.
Hopefully, I've captured all the information needed to help point me in the right direction.
Input voltage (before boost converter): 5v @ 1A (5W)
Load: Fan (rated for 12v @ .06A)
DC Boost Converter Without load: 12v
With load: 5.66v @ 22.1mA
Works with new 9v battery
