Small Circuit board with large capabilities
mkakasapu
Joined Apr 9, 2020
19
Hey all,
I Want to build a system that can
1. Run motor
2. Play music
3. Take commands over wifi
at the same time
This is kind of musical mill which rotates (with forward, backward, speed change capability) and play different music tracks based on the commands received from wifi interface.
The challenge is the whole system needs to be Tiny (To give an idea it will be N scale).
I am kind of programming guy but less knowledgeable on hardware side. Hoping somebody will help me to optimise my circuit.
By my research, I found the following are the smallest which I can work with..
1. AtMega328P chip
2. L293D chip for running motor
3. ESP 01 module Wifi for communication
4. MicroSD card interface for storing music files
5. I will get a PCB that connects all these together.
My question is what is the most possible way of reducing the size as much as possible (smaller alternatives for circuit and chips) and get perfectly working setup?
Is Atmega328P is capable of doing all these tasks simultaneously ?
Any working prototype will be appreciated..
Thanks in advance.
MK
mkakasapu
Joined Apr 9, 2020
19
Apologize if the question is too generic or broad to answer. Any suggestion on Motordriver chip SMD version which exactly work like L293D?
djsfantasi
Joined Apr 11, 2010
9,160
Where is this going to be installed? On an N Scale layout?
Do you have a motor that fits inside the mill?
I’d mount everything underneath the layout, which gives you more space to work with. You might be able to drive the windmill with gears so as to mount the motor underneath as well. For example, a set of spur gears or a worm gear drive.
mkakasapu
Joined Apr 9, 2020
19
Yes. But I am also looking for opportunities to put it inside N scale loco. I know there is DCC but I want to try this on my own.
Thanks for reply
MK
mkakasapu
Joined Apr 9, 2020
19
For now I am thinking about the electric locos as these have bit space & are in rectangular form that allows board.
I also realised generating polyphonic sound (or just sound) is complex task. Atleast If get basic moving then I will think about advanced features like propulsion, sound etc.
Just keeping my expectations down for now.
