Currently I am trying to power an Arduino project with a mechanical battery. I am using a stepper motor (NEMA23) as generator for it only needs low RPM to reach full potential (Around 600 RPM). Output of the stepper was determined at 1.8A AC @ 33V. This should be enough power for all the components. However, I am unable to regulate the voltage to do this.
The following components need to be powered:
- Arduino Uno with servo motor (9g) attached
- CNC shield with 2 stepper motors (NEMA17) attached
A schematic view of the system is found in the attachment.
What components do I need to regulate the power to be able to make this work? I hope this is possible.
