Hi there,
In the circuit below I am trying to take just 12V off a capacitor that is rated at 16V (can't find 12V ones easily) and which is fed from a 25V one in a chain and I am querying the best way to do this.
My first thought is to use a potential divider to tap off the required voltage but am wondering how to calculate its rating since some of the lots volts will have to be dissipated through the resistor. I'm guessing that the maximum current that might be drawn down from the string of 100uf (25V) caps might be 5A. I'm just trying to get the principle and calculations right. Also, is the 16V cap the right way round to draw off any charge/power?
I'd rather not waste power in the resistor but don't know another way to step down the voltage. Any thoughts welcomed.
