Hub motor with separately excited rotor and stator configuration
Quintos
Joined Mar 7, 2020
9
Hello all,
I was wondering if its possible to develop a hub motor design with separately excited windings for both stator and rotors (i.e. No use of Magnets). I am exploring this idea for the use in rotation systems where free wheeling can occur when not powered.
What do you think? Is it possible? or are there any other solutions to this? (apart from freewheel clutches)
shortbus
Joined Sep 30, 2009
10,045
What do you have against free wheel clutches? The problem with separately excited rotor ans stator in a hub type motor is the need for them to be narrow instead of wide, to get enough power out to do the moving.
If your interested in something that will work in that situation, thin and no magnets, except windings on a stator, you should look at SRM(Switched Reluctance Motors). It's one of the earliest electric motors developed, but wasn't widely know until recent times. Now that there are solid state switching devices it is in much wider use today. https://en.wikipedia.org/wiki/Switched_reluctance_motor
There is much literature available out there about them and their drives too.
https://www.google.com/search?client=firefox-b-1-d&q=Switched+Reluctance+Motors
Quintos
Joined Mar 7, 2020
9
What do you have against free wheel clutches? The problem with separately excited rotor and stator in a hub type motor is the need for them to be narrow instead of wide, to get enough power out to do the moving.
Can you elaborate on this for me please? Do you have any links that I can look through in depth?
Thanks Alec, I am well versed with the standard wound field configurations - series, shunt and Compound, What I am interested is in the application of separately excited windings in the Hub style motors - Outer rotors and inner stators and I cant really find much on this :-\
shortbus
Joined Sep 30, 2009
10,045
Why do you think most every hub motor is a BLDC type? They allow concentrated power from a narrow package. Then when both motor elements are energized you also need brushes of some sort. The reason you can't find any information is no one is doing it, or at least no one that is serious about it and understands motors. The SRM does it with no magnets like you asked for.
Quintos
Joined Mar 7, 2020
9
Thanks Shortbus, I will look into SRM, I am not particular about eliminating brushes, My main idea is to eliminate cogging torque and on cursory glance, SRM seems to have torque ripple at low speeds, my motor will start from 0 rpm and may go upto 1200 rpm and will require a sufficiently large torque to carry a load of 150-200 kgs from speeds of 0 to 60 kmph. So the low speed performance is needed.
18,502
It should be possible to eliminate "Cogging torque" without resorting to wound field technology. For starters, none of the ironless rotor motor types have any cogging torque, nor do most induction motors. Replacing magnets with coils certainly reduces efficiency a fair amount. What is the intended purpose of such a motor, anyway? What specific benefit are you seeking?
Quintos
Joined Mar 7, 2020
9
I am working towards a hub type motor to be used on e-bike or mopeds, Induction motors are out of the list as there wouldnt be enough cross section to get a decent enough of torque out of it,
Specific benefit - I need the wheel to rotate freely when the electrical power is exhausted or not in use.
18,502
OK, for an E-Bike it is an interesting application, and one that would not tolerate the power wasted in a wound-field motor. Skewed rotor slots have been used to reduce the gogging effect for many years and are fairly well understood by motor designers. And if there is any apparent cogging effect I suggest that it is caused by the driver circuit somehow allowing current to flow while the drive is not powered but the wheel is rotating. That is, a poorly designed driver circuit.
shortbus
Joined Sep 30, 2009
10,045
I'm pretty sure you are overstating the cogging effect in a hub motor. The difference in diameter of the hub over the wheel would or should make it negligible. If it wasn't, there wouldn't be so many hub motors out there in the market.
Hub motors were even being talked about and developed a few years ago for use in cars and trucks. The SRM motors are used a lot today in deep mine machines to drive the wheels and hydraulics.
Quintos
Joined Mar 7, 2020
9
NONE of the ironless motors that I have used or worked with had any cogging torque that I could detect.
How big can these get? It seems a heavy load can cause the motor to heat up and burn up the wiring. They are better for applications where the loads are pretty much unvarying.
18,502
Are you referring to P.M. field?
If so cogging is prevalent especially when run in BLDC mode and where motion feedback is absent.
Max.
Max, what the TS is wanting to prevent is cogging while the motor is not energized. Apparently this is a complaint on a hub-motor variety of electric bicycle. At least that is the concept that I got from the TS post. I have tried out two different electric bikes and did not notice any such cogging effect, but I also found the claims of the sales person totally non-believable.
strantor
Joined Oct 3, 2010
6,798
Why is this cogging something you need to design around? How much cogging do you think comes from a single cylinder 4stroke engine like would normally be employed? That's one cog/pulse per every two revs, surely more perceptible "cogging" than would be felt by a BLDC with some multiple of 3 cogs/pulses per rev? And yet nobody complains of this? Is it really a problem? Seems to me at most it would feel like a slight vibration below walking speed.
18,502
And keep in mind that the TS is wanting to prevent the cogging with a NON-POWERED motor. Looking again at the initial post, it is not clear just what the application would actually be. Post #8 indicates that it actually is a bike of some form.
