What power factor differences can be observed when changing the frequency?
Dane T
Joined Feb 19, 2020
Hello there, I'm struggling on a question that I had received I was wondering if someone could give me the correct answer and explain it to me
Thank you.
Frequency: 503.29Hz
Current: 55.96A
Total Resistance: 4.11Ohms
Voltage Supply: 230V
Inductive Reactance: 31.62H
Capacitive Reactance: 31.62F
Power factor: 55.69^2 x 4.11
= 12.7kW
Frequency: 60Hz
Current: 0.88A
Inductive Reactance Value: 3.77Ohms
Capacative Reactance: 265.25ohms
Power Factor: 0.88^2 x 4.11
= 3.18W
This isn't really my strong hold, so I was wondering if anyone could help me answer the question by observing the values I've given above for two different frequencies
Thank you.
WBahn
Joined Mar 31, 2012
30,082
We don't provide answers to homework problems -- that defeats the purpose of homework.
You need to show your best attempt to work/answer the problem and then we can help you move from their toward where you need to go.
First, review what power factor is? Hint: It is NOT a power (it does not have units of watts).
Dane T
Joined Feb 19, 2020
Apologies, I didn't know but I had already written up something just didn't know if it was correct.#
My answer:
The relationship between power and frequency is inversely proportional to each other. At 503.29Hz XL = XC this is called resonance condition. In this condition the inductive reactance gets cancelled by the capacitive reactance. Therefore, the entire RLC circuit acts as a resistive circuit, and the power factor is Unity.
Dane T
Joined Feb 19, 2020
I just went over everything, and reviewed Power factor. Turns out I was using the wrong formula to calculate it apologies. Therefore the above value is incorrect.
New Value for power factor @ 503.29Hz
\[ Cos\theta (4.11/4.11) =0.99 \]
New Value for power factor @ 60Hz
Impedance: 261.51Ohm
\[ Cos\theta (4.11/261.51) =0.9999 \]
\[ Power factor Formula:Cos\theta (R/Z) \]
