Battery Management System ideas for twenty 3.2V 100Ah batteries connected in series
devinkkperry
Joined Jan 29, 2020
7
Hi, I'm part of a team continuing the development of an electric vehicle at my university and I would like some guidance in implementing a Battery Management System for the power supply that is already in place.
There are currently twenty 3.2V 100Ah batteries (attached below if it helps) connected in series as it needs to power two 60VDC 2500W drive motors and one 60VDC 410W servo motor.
My main concerns are 1) short circuit, overcharge, and over discharge protection and 2) balanced cell charging.
My experience in circuits is more limited than my budget, so I prefer to pay more for plug and play if it means less DIYing.Screen Shot 2020-01-29 at 1.40.39 AM.png
Dodgydave
Joined Jun 22, 2012
11,307
You can buy ready made modules for 2, 3 or 4 cells, which will do the job of balancing and current limiting, you just need the correct charger for the cells.
pmd34
Joined Feb 22, 2014
527
This company has BMSs for such batteries:
https://www.ev-power.eu/
But if you want to do it yourself then, have a look at the MY2112 and HY2212 BMS ics.. there are also others available from that manufacturer, though you would have to adapt the circuit to cope with such very high currents.
Be very careful about buying batteries from China however, as many suppliers sell batteries with false capacities, and even second hand batteries, as new.
devinkkperry
Joined Jan 29, 2020
7
So I'd need 5 of those modules I assume. Do those 5 modules need to be connected to each other to collectively manage the 20 cells or is it fine if they independently manage 4 cells each?
devinkkperry
Joined Jan 29, 2020
7
Thanks! The BMS123 Smart https://www.ev-power.eu/Battery-Man...-Complete-Set-4-cells-with-Bluetooth-4-0.html looks like just the thing, but how might I adapt the circuit to cope with 60V 45A?
