LTspice Simulation Question
raventrob
Joined Jan 28, 2020
Hello All,
Currently I've been doing some parametric sweeps with components and temperature. If I perform both a parametric sweep with a temperature sweep is there a way to extract or plot the data for one of the temperature points? For example lets say I perform a transient sweep while measuring "Vout" and stepping a resistor over some range while simulating ".temp 0 100 10", can I plot or extract lets say just the data for 50C?
Thank you
raventrob
Joined Jan 28, 2020
@ericgibbs So basically what I'm doing is a little more complicating then what I described in the original post.
I am sweeping the input power level from -30 dBm to 0 dBm and then using the .meas function to obtain the RMS voltage for the input and output nodes then using some math to convert to dBm so that I can plot Pin vs Pout using the Spice Error Log. What i'd like to do is simulate for 3 different temperatures and plot 3 different Pin vs Pout traces, the problem is I cant distinguish the temperature data from each other when I go to plot.
eetech00
Joined Jun 8, 2013
3,953
Hello All,
Thank you
hi
look in the error log file and determine which step number represents 50C.
Then, in the plot window, add to the window label @(the step number)
Example
pout@10
eT
raventrob
Joined Jan 28, 2020
Okay look at my picture below. As you can see the data I want for "Pout" is shown and I know all the even step numbers are 25C and all the odd numbers are 50C. So you are saying I can specify which step numbers to plot? @ericgibbs
eetech00
Joined Jun 8, 2013
3,953
Hello
Open the log file.
Locate the data for "pout"
Right-clk on "pout", then select "plot stepped .meas data"
A plot window will open.
Click in the plot window, rht-clk and select "add trace"
select "pout", it will be displayed in the plot window
you can change the axis' as desired.
eT
