It is reset.never mind. I thought pin 4 was reset...let me try
if you connect pin 4 to ground permanently, the timer will never run.So do not disconnect any of the pins? Just connect pin 4 to pin 1 for ground?
It's unwise to leave any input pins floating.So do not disconnect any of the pins?
