Ceramic Antennas vs Stamped Metal Antenna
Filand
Joined Oct 17, 2019
8
Hello.
What is the main differences between ceramic antennas and stamped metal antennas? I find a lot of comparisons of either one to PCB trace, external, etc, but haven't found one who compares these two. Thanks!
"RF ANT 2.4GHZ/5.5GHZ STAMPED MET"
"This is a monolithic SMD 2.4GHz antenna. Works well for any 2.4GHz application, including WLAN, Home RF, and with Bluetooth® applications."
Janis59
Joined Aug 21, 2017
1,849
On the edge of senses I feel the ceramic is epsilon more than one media, it means that part of waves are trieng to escape the entrance in it. Thus, probably, the identical size antenna may have a diminished Gain factor. But as sure the capacitative environment demands a smaller inductive component, the antenna vibrating elements will even be smaller as those in air, thus the Gain will be much more diminished. Thus - there are two factors eating off the good Gain.
