Hi everyone,
I have some electronic motion switches that when we switched from incandescent lamps to LED lamps, there is not enough of a load to stop the triac in the switch from leaking current when it is off and keep it stable when it is on. I done want to put a dummy load in the circuit, because that will only consume power, when saving power is what we are trying to achieve. I have stumbled across the Aeotec Bypass. https://aeotec.com/z-wave-low-voltage-dimmer/ In their manual for it, they say that it is a capacitance device. Seeing that it only takes 4 watts, I found it was an interesting option, until I saw that they are $20 a piece. For that cost, I could replace the motion switches with new ones. Does anyone have an idea of what type of cap I would need for this?
Thanks!
PS, if this isn’t the best forum for this, please let me know.
Thanks!
