Hi,I want to know the output currents of the photodiodes.but this information is not given in the Datasheet.How can i learn it?
Photodiode model SD003-151-001
I couldn't switch my current. Can you help meThe responsitivity of that photodiode is given right there in the data sheet: 0.9 amperes/watt of incident energy at a wavelength of 1310 nm and a reverse bias of 5 volts.
From that, and from the intensity of the illuminating source, you can calculate how much output current to expect.
Or, you can just measure the current with the diode illuminated.
I've given you all the help I can, based on the extremely limited information you've provided. And I have no idea what you mean when you say, "I couldn't switch my current."I couldn't switch my current. Can you help me
Our Turkish isn't very good .My english is not very good.
