Why op-amp generating output while no input?
ericgibbs
Joined Jan 29, 2010
18,874
hi R77,
Welcome to AAC.
The Rfb resistor is incorrectly connected to the +Vin . it should be -Vin.
E.
Also you should have a resistor in series with the 3v3 zener.
Sensacell
Joined Jun 19, 2012
3,453
The 3.3 V Zener there is a bad idea, even with a resistor.
1) The opamp will basically see a short when the output tries to push beyond 3.3V, this will cause maximum current/power dissipation and quick failure.
2) Zeners are not terribly accurate, the clamping voltage will not be very predictable.
3) Zeners don't typically have a super sharp threshold, they start to conduct more gradually than you might expect.
Reasons 1, 2 and 3 mean that even with a resistor to limit the current flow, the upper ADC values close to the threshold may become non-linear.
Use a simple diode/resistor to clamp the output voltage to the 3.3V rail, with an additional resistor before the ADC input to limit any current flowing into the MCU's input protection diodes.
Essentially the external diode is in parallel with the internal one, the extra resistor ensures that the external diode sees most of the clamp current.
This network will never conduct any current within the full ADC voltage range- no chance of non-linearity.
Romie77
Joined Jan 4, 2020
41
hi R77,
Welcome to AAC.
E.
EView attachment 196033
hi R77,
Welcome to AAC.
E.
I will change the position of resistor and capacitor and get back to this thread.
ericgibbs
Joined Jan 29, 2010
18,874
hi,
OK,
What is the source and range of the input signal.?
You have shown +/- inputs , but one input is connected to 0V.?
E
Romie77
Joined Jan 4, 2020
41
hi,
OK,
E
Its a DC input varying from 0 to 10V. As the output reach the 3.3 volt, processor is program to shutdown the particular part of the circuit. Hence I dont need output above 3.3V also it may damage the processor.
Romie77
Joined Jan 4, 2020
41
Thanks for your detailed explanation.
Romie77
Joined Jan 4, 2020
41
hi,
Using a Rin of 10k and a Rfb of 10k, the inverted Gain will unity.
Would you like me to draw a OPA circuit.?
E
Yes. You and all the people reading this thread can explain things. It will increase understanding of do's and don't to make new circuit.
ci139
Joined Jul 11, 2016
1,898
your inverting input is ?
  1. shorted to signal ground ?
  2. has a floating antenna inductor attached to it ? e.g. no DC path to anywhere but -inp and output
your schematic doesnot define in unary understandable way
? are your inverting a and non-inverting op-Amp inputs corresponding to your labelling ←→ the capacitive feedback to non-inverting input would likely cause oscillation
Refer to https://www.electronics-tutorials.ws/opamp/opamp_5.html
Romie77
Joined Jan 4, 2020
41
hi,
Have you considered a simple resistive voltage divider.?
E
The resistor divider will affect the time needed for sampling by ADC, whereas op-amp will do so but to a significantly lesser degree. I want the output response as fast as possible.
danadak
Joined Mar 10, 2018
4,057
Something like this -
Make 5V lable 3.3V, the diodes preferably schottky although most people using
small signal Silicon like 1N914, the 100 ohm more like 1 K ohm. That will protect input
to processor.
Regards, Dana.
