8 Function Light Controller
HighVoltageJoe
Joined Jun 1, 2017
36
I have a cheap 8 function light controller that is rated at 3.6-36VDC at 500mA max current that I want to control more than 500mA worth of lights with. Looking at the circuit, it seems that there is an EEPROM on it and then an unmarked IC. I would reverse engineer this circuit but have no idea what the function of that IC is. Would it be worth it to model a new circuit and just place the EEPROM on it or would it be easier to possibly feed the output of the 8 function controller into another circuit that can handle more current (possibly feed the output into a triac or something)? I would like to keep this as simple as I possibly can, but have no idea what I am getting into...IMG_8348.jpg
Dodgydave
Joined Jun 22, 2012
11,301
Looks like Q1 to Q4 are the light/led drivers, so improve the transistors or use slave transistors to get more current with a better psu.,
Honestly with the amount of xmas lights on the market now, it's cheaper to buy a better set than modify it...
The 24C02n is an Atmel eprom..
ci139
Joined Jul 11, 2016
1,898
/!\ just a quick look suggests your adapter/supply [-] goes to the C- and [+] goes to the +A
as the +A is connected to the E(mitter) or S(ource) of the Q2 and Q4 the L1 and L2 are likely positive voltage outputs to the LEDs' anodes
you can take that + signal as an input to whatsoever power amplifier circuit - and attach a half of the city there if you afford . . .
