what is this transistor?
SamR Joined Mar 19, 2019 5,053 Jan 1, 2020 #2 Welcome to AAC! It's not a transistor. It is a Light Emitting Diode, LED.
dl324 Joined Mar 30, 2015 16,943 Jan 1, 2020 #4 Welcome to AAC! Need more information. It could also be a phototransistor or photodiode. EDIT: Or a flashing RGB LED (courtesy Adafruit):
Miracletech Joined Nov 15, 2019 160 Jan 1, 2020 #5 Either a LED or Photoresistor. You'll have to run some tests to determine If it is any Of the Above. Good luck.
Dodgydave Joined Jun 22, 2012 11,307 Jan 1, 2020 #6 Circuits58 said: what is this transistor?View attachment 195781 Click to expand... If you have a Dvm, put it on Diode test and put the meter probes across it both ways, if it lights up it's a Led, if it reads voltage or Ohms, one way it's a photo transistor,,
