Good Morning,
I'm trying to build an inverter welder that has a 400 amp output using both AC and DC while using the 120volt wall outlet I have the parts That I want to use in mind, and I need these parts connected to the PCB I'm looking for advice they are as follows:
1) 32 bit 64 pin microcontroller
2) 12 volt Gas solenoid for the welders shielding gas
3) 24 volt Roller motor for MiG welder electrode.
4) 3-5 volt tiny 1 inch lcd display
5) Four 5volt rotary encoders to adjusts the settings of the welder.
6) 32 pin 5 volt 7 inch oled display.
I plan on using the C++ coding language to do this. I imagine fifty percent of all electronic engineering and PCB design involves taking power that cannot use in its current voltage rating and either increasing it or increasing it to power that we can use run the electronics we want.
My challenge now is getting help to get into the fine print of the PCB design such as capacitor, resistor component placement and the math needed to get the right answer. I have a crude schematic attached for your review
