Hi All,
I have a problem and I believe it Is simple for you but I am not experienced so I need your help. I have two devices that needs to be connected to each other with ribbon cable, one device has 2.54mm pitch connector and the other one has 1.27mm connector. I got all the connectors and now I ran into the problem, it seems that the ribbon cable for the 1.27mm connector has obviously different pitch than the 2.54mm, is there any ribbon cable in the marker that is one pitch from one side and another pitch from the other. If not then how what pitch of the ribbon cable I need to buy to use the 1.27mm connector and how can I connect two ribbon cables of different pitches together?
