7 segment clock, size issue
rahul411
Joined Feb 19, 2018
260
I'm making a 7-segment display clock with display size of 2.3inchs. i have done a rough layout for this and observed that trace lengths are too long. I dont know whether it will cause any delay or latency in signal propagation as such, I'm just concerned that it will cause some issues with multiplexing.
Is this right or not?
PCB layout is posted it is not complete, Im going to use perf board for laying down components.
AlbertHall
Joined Jun 4, 2014
12,347
At the frequencies you might sensibly use for multiplexing (100Hz - 1kHz) the lead length will significantly affect the operation.
pmd34
Joined Feb 22, 2014
527
Hi rahul, I dont think you need to worry about latency until you get to very high switching speeds well into the MHz.
