I've done quite some research on MOSFETs but I'm not 100% sure I understand them correctly and as I'm about to start trying things out I'd like to ask someone to point out any mistakes I'm about to make and spare me the smoke effects and light shows, please.
So I have a DC motor(drawing about 10 - 15Amp) running off of a battery which has an operating voltage range of 8.4V to 7.6V, I would like to switch the main power line for this motor on and off using this IRF3205PbF mosfet rated for 200Watts, 110A, 50V. It is to my understanding that the gate which is "voltage-operated" draws only as much current as it needs and therefore I can connect it directly to the same 7.6V through a switch and the gate should draw near 0 amps from the battery to turn on the mosfet when the switch is on. I can then just add some pulldown resistor, let's say 10k ohms for when the switch is disconnected to ensure that the mosfet switches off after I turn off the switch. I'm a bit worried that the mosfet won't be conductive enough with only 7.6V on its gate though...
As for the reverse polarity protection, I understand that a Schottky diode and capacitor are a favorable combo, but I don't have a single clue as to how to go about calculating the power requirement of the Schottky diode. Would some generic 1A 30V Schottky be enough or should I use something meatier? As for the capacitor it doesn't need to be very large, say 100pF or should do?
Here is my planned schematic:
