the touch controller does not operate properly when powered by any of my constant current single led drivers that I use with my manual knob dimmers.
so I just connect my little touch sensor to a 12volt wall wart and measure for runaway by using a lumen meter. If left with no limiting cuircutry the led would melt down in a few hours at the high brightness setting ....thru the range the pwm from the touch controller stops runaway but at peak brightness
there is no limit and the led continues to brightness and temp ramp...would the right resistor in line between the led and controller work? I tried 2 diff resistors that was 90ohm and another tiny one that was connected to 5mm led and my light was just barely turning on.
