Superconductor self-discharge rate
HugoMorris
Joined Nov 29, 2019
11
I'm a newbie to electronics with an interest in paper batteries as a hobbyist. Does a multimeter act as a load when testing voltage ? Mine seem to self discharge in minutes. I'm using a good conductive ink and separator on a low voltage charge but getting poor results.
jpanhalt
Joined Jan 18, 2008
11,087
Yes, a multimeter acts as a load when measuring voltage. The amount of load is highly dependent on the type of "meter." Older analog meters put a relatively large load compared to modern digital meters.
As for the rest of your question, can you post a drawing of what you are doing?
bertus
Joined Apr 5, 2008
22,278
As @Alec_t said, it sound like you are making a capacitor.
A superconductor is a special kind of wire that looses resistance when made very cold.
Most times liquid helium is used to make the superconductor.
Liquid helium has a temperature of -269 °C or 4 °K.
I can change the title of the thread if wanted.
Bertus
34,468
Yes a multimeter acts like a load. It is rated in ohms per volt.
Analog multimeters are rated in ohms-per-volt (where the volts is the full-scale setting).
Digital multimeters usually have a fixed input impedance (typically 10megΩ on the DC scales) which is independent of the scale setting.
