I want a firing circuit that can do as the arduino do with variable potientiometer and the pulses should be 1ms , i want it to fire electronic devices such as triac or SCR at angles all around the sine wave .What will you be doing with the firing circuit? e.g. Motor speed control, lamp dimming, power supply regulation, etc?
Do you need switching at the zero crossing or continuously variable firing phase?
Will the primary control be a control voltage, a pot, or other?
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Jake Hertz
