Hello!
I figured out how to wire the components but I have some questions.
1) These nail pins won't fit in the board holes. I even tried to pierce the board with the pins using a hammer.
2) The ground, ends up on pin number 2?
3) Pins 3 and 4 are the output, right?
4) Do these grey markings on the boards means that its a short-circuited? So these two capacitors (orange) with the two diodes are connected
to each other?
The kit has an ac adapter with 4 different diameter barrel plugins but no power jack to connect to the board. I bought this one (I hope its
the right one).
Also, I don't have that soldering tool, so I just thought to wire the components together with the help of pliers and insulating tape
Also if you watch carefully, next to c4 (the black capacitor) and below it there are some leftover holes. I don't know why.
to each other?
the right one).
