Antenna for RDA5807M FM tuner chip
Piotr Mackowiak
Joined Aug 17, 2019
9
I got the module of FM tuner (picture above) working properly with Arduino. This is small 1x1 cm PCB containing only RDA5807M chip (I2C control) and quartz crystal.
The problem I have is poor sensitivity because of antenna. At this moment I just solder piece of wire to ANT pin.
Poor sensitivity exist due to the temporary antenna. At the moment I just soldered a piece of wire to the ANT pin.
I'm not a specialist in antennas, hence I wanted to ask more experienced colleagues.
The same chip is used in many smartphones, where the headphone cable is used as the antenna. I use it in the Arduino project as a "desktop" device. I tried to connect the telescopic antenna to the pin but it did not increase the sensitivity of the tuner. At least to a small extent.
So how should the antenna be properly connected and what other (most likely) elements to use so that the whole device has the same good sensitivity as in a smartphone.
Anyone can help me?
ci139
Joined Jul 11, 2016
1,898
if the MCU interface --and/or-- Vdd introduces noise that "saturates" the input amp - the antenna may not be the primary issue
Janis59
Joined Aug 21, 2017
1,834
The hobnail is the best antenna ever if signal is strong, but if not, the nail`s length must be adjusted with network analyser as well the counterpoise too. If even that is not enough, the next step is to enroll a J-pole antenna because of it unical quality of narrow diagram, shining only aside but never upside and downside. We have no need to make a light in the head-up, therefore this antenna gives hard ster forward inspite it is till omnidirectional. However the gap distance between it both branches have a critical in bounds of micrometers. To change say 5 mm distance toward the 5,05 means catastrophe in characteristics, therefore still the good construction for HF RF is in the search. Pcb is not applicable there because of FR4 has tan delta so high as about 0,3%, but better materials as Duroid(TM) is bit expensivish with it 650 USD per A3 sized sheet (tan delta 0,0003 at 1 GHz). Next step forward is to condemn the omni, and then for 2,4GHz the fine idea is "can-antenna" (may find a plethora designs in the web) of for lower freq the Yagi-Uda. In the last case it ought to use the metal-less electrotech cabling pipe of styrene, where resonators are fixed by own isolation, I mean cheapest alu or Copper electrotech monolite wires with thick insulation. Then isolation is fixing it not fall out (drill the holes in pipe by copper diameter) as well preserves it against an atmospheric waters and oxidation. But my experience tells the work for passing it is just damn, as all the insulators carry within the certain unknown shortening factor dependant on insulator material and even thickness.
ci139
Joined Jul 11, 2016
1,898
it is also dependent on your relative geo location to nearby stations , time of the day , weather , indoor antenna location/positioning , indoor antenna geometry & "direction" . . . Earthing your SG (signal ground) to central heating/separate grounding rod/conductor may have some benefit occasionally
Piotr Mackowiak
Joined Aug 17, 2019
9
Replying to everyone, I am aware that distance from the transmitter, weather conditions etc. are important, and of course the length of the antenna. I count it to myself. 1GHz corresponds to a wavelength of 30 cm. Hence 100MHz is 3m.
Antennas should have a quarter of wavelength. Hence the optimal length for the FM range is something about 70 cm.
But. My smartphone has exactly the same RDA5807M chip. Any headphone here serves as an antenna - specifically - literally any Chinese no-name, bought for a few cents. Headphone cable length - whatever. How much Chinese have cut. Plug quality, connection capacity, inductance - no further known.
And I compare the sensitivity of the receiver in the smartphone with that bought in the form of a module. The smartphone receives everything possible. The module only has the 5 strongest stations. The rest is noise.
Hence the question. How to make an antenna for such a module ...
Prześlij opinię
Historia
Zapisane
Społeczność
Audioguru again
Joined Oct 21, 2019
6,671
The radio in a smart phone has a good pcb layout so it works properly.
The module made in China with no proper pcb design works poorly.
Maybe the Chinese module uses a cheap copy of a real chip.
ci139
Joined Jul 11, 2016
1,898
you can try to pack your '5807 PCB into a tin foil or mount it into Al+ casing ... which likely has no effect coz there's no much pickup traces on the tiny board . . . what i kept in mind is that
(-1-) the I/O wiring data/power may bring/pass noise to your module that is stronger than ANT.inp try the ferrite HF supressors around power lines
(-2-) the attached cables also work as antennas that may result 0° phase difference in your ANT amplifier input (FM.in , GND)
i thought something as a loop of wire that
. is attached (soldered) to amplifier side of ant. cable
. runs some length along it then curves back and goes through series RC or C only to the GND
/// i doubt ↑ it ↑ has any significant effect but is worth to try
KLillie
Joined May 31, 2014
137
A few "things" since I've have been working on one of these lately. Make sure your power supply is solid. I am running mine at 3.3 volts from rechargeable batteries through a voltage regulator. If your power gets too low you gonna have problems. I'm using a 1/4 wave length wire with a small ceramic cap. between it an the the antenna pin. After re-reading more of your post...try changing your SNR higher or lower.
KLillie
Joined May 31, 2014
137
Could you please elaborate?
I can pick up quite a few stations with what I mentioned before, but I could pick up more when I changed the SNR. I'm guessing the signal to noise ratio is squared according to the data sheet/manual. It is somewhat secretive. The default is 1000 binary or 8 out of 15. If it is squared that would be 64 or 64=signal over/ 1=noise. So lower it to 7 or (0111)!
NOTE: I ordered my chips/board from China. It's an RDA5807M chip on a board with a few components. The most noticeable being a 32.768kHz crystal. I ordered 3 and they sent me 4. I thought I was getting a deal. I screwed up the solder on two. Another worked for about a minute. And my LAST one is now giving me fits. I can't change the volume. So the OP shouldn't feel bad if they have problems. They're not the first.
Zebryk
Joined Nov 15, 2012
FM Broadcast is only 88MHz - 108MHz which does not require high precision in layout, materials or components. Perhaps this very inexpensive from China is damaged, or became damaged with your soldering attempts. A reasonable sanity test would be to compare it to another known good unit of a similar design.
KeithWalker
Joined Jul 10, 2017
3,063
I ordered four RDA5807M modules from China. I could not get any of them to work at all. Then I ordered three Si4703 modules. These all work really well. They are sensitive and selective and very easy to program.They even have a built in headphone jack. I tried one connected to an amplifier and a 70 cm wire antenna. It worked well even in the basement.
Keith
KLillie
Joined May 31, 2014
137
Keith
Dang, and I just ordered 18 more! (Only about $7.00 lost if I can't get any to work) I'll check out the Si4703 modules. Thanks
KLillie
Joined May 31, 2014
137
All this stuff is breadboarded for right now. There's no doubt I screwed up at least one with my solder. I've got more coming to try for a favorable outcome.
Al Brown
Joined May 14, 2020
Anyone can help me?
Al Brown
Joined May 14, 2020
I am just using a straightforward wire coupled into the board with a very short PCB track. The reception is quite incredible and its been fun to debug and program as you get to hear the results. I think it was about 83cm in length and just bare copper wire.
Janis59
Joined Aug 21, 2017
1,834
83 cm is "short"??? I would say 8 mm is killingly LONG. But OK, may use the nano-VNA for debugging. Fits better than hammer on nail head.
