MOD-60 counter with stop/start and reset buttons
XxdeadshotxX
Joined Nov 8, 2019
28
HI all
I am given an assignment by my lecture. We are using 74LS93, 74LS00 and 74LS32 ICs to build a 60 seconds stopwatch. . I have some problem building MOD-60 counter from 00 - 59 in multisim. I have connect the these two ICs to two 7 segment LED common Anode.
I do not know how to add in stop/start and reset buttons also. The reset button switch will clear or reset the mod-60 counter to 00 when activated. ie, 00 until it is started again through the use of the start/stop switch.
when the mod-60 value is running , activating the start/stop switch will stop the counter at its current count value, ie, 40, which indicates a time lapse of 40 seconds from the start. Reactivating this same switch will cause the mod-60 counter to resume from this previously stopped value.
We are given other F/F IC like 74LS74 and 74LS112
Pls help me!!
thx
bertus
Joined Apr 5, 2008
22,277
What is the size in pixels?
It can be that a side of larger as 1280 pixels will be rejected.
Bertus
bertus
Joined Apr 5, 2008
22,277
I already notified the technical admin about the issue of uploading pictures.
Can you rescale the picture to 1280 a side?
This can likely be done in a paint-like program.
Bertus
ericgibbs
Joined Jan 29, 2010
18,849
hi,
Is this summary of actions correct.?
If yes, first show your idea how to Reset to '00'
E
Summary:
1 Reset Counter to '00'
2. Start/Stop Counter.
3.Count from 0 Sec thru 59 Sec and Stop or Auto restart at '00'
LesJones
Joined Jan 8, 2017
4,190
That is just a block diagram. What is inside the two blocks in the box surrounded by the dotted line ? Are you ONLY allowed to use the ICs listed in post #1 ? If so you will have to design a decoder to drive the 7 segment displays. (This would normally be done with a decoder/driver IC.)
Les.
ericgibbs
Joined Jan 29, 2010
18,849
hi,
As I read the TS's project, its a simulation in Multisim, no indication of a visual numeric display.?
E
Update:
This may help as a starting point, edit as required.
XxdeadshotxX
Joined Nov 8, 2019
28
ye
Les.
Yes. Everything that is provided are listed in post #1
ericgibbs
Joined Jan 29, 2010
18,849
hi X,
As this is Homework we need to see your attempt at connecting the IC's in the project, we can then advise you.
E
BTW:
The LS193 is a alternative counter, but you should use the the type given by your tutor.
XxdeadshotxX
Joined Nov 8, 2019
28
hi X,
E
BTW:
Yes sir, do not spoon feed me. i will go home later and try to come out with something with multisim:)
XxdeadshotxX
Joined Nov 8, 2019
28
hi X,
E
BTW:
Hi i want to ask if i need to have clk pulses do i connect vcc to it also or there is other connections?
