Hi, guys!
3dprinted and built the following generator off thingiverse: https://www.thingiverse.com/thing:1693579
Then I wanted to modify it by building an outside rotor with the same number of magnets (32 magnets in halbach array = 16 poles). The idea was to lower the gap between coil & magnet and increase the radius a bit for higher lever force(not sure if that's the term)
You can see the new design on top. At the bottom is the original.
Unfortunately the new design doesn't do anything. Just 0 Voltage no matter how much rpm I put in. The coil has 4ohm resistance, it's serpentine coil. I though that I've shorted it somewhere (even shorted should get some minimal voltage?). So decided to put a second coil - same thing.
The halbach array is working as it should as the field is on the inside (testing with metal rod). Field is alternating when turned (testing with a compass).
Does anyone has any clue what's the problem? Could the change of radius make the currents in the coil cancel out completely(I can't be that good )?
