I wanted a digital piano for a long time , but I also knew - it that was not going to be used more than five times a year ... so the money was not worth it.
I got myself a broken Kawai CL35 and I will be very happy to repair it.
The piano is turning on , but there is no sound from the keyboard.
When turned on I can start the metronome , but if I touch the keyboard (any key) , the metronome stops and can't be started again. Same is the case with the Concert magic and lesson - melody is starting to play , but in the moment I press any key - the melody stops and the only way to start it again is to restart the piano from the on/off button.
The piano has not been used at all or very little , I can see a quality control label from 2008.
I looked for any bad looking caps , actually I have Fluke that can measure caps , so all of them read in the range they need to be .
Checked for anything that you can see with a naked eye on the boards ... they look like new.
Checked the cable from the CPU board to the keyboard , there is 3.1v and 5v on all the wires to the keyboard when connected.
When pressing the keys and measuring the 5v , can see a small voltage drop to 4.8v , which makes me think that they keyboard is okay , but the signal from the keyboard to the board or something with the signal is bad.
If you have any ideas for further troubleshooting , please share them here Thanks
When I try to this - works, metronome is adjusted nicely with the black keys.Step 1
Press and hold the METRONOME button, then select the desired time signature by pressing one of the
lowermost black keys assigned to that beat.
