Traffic Lights Using Buttons/Switches etc..
Ariel Arevalo
Joined Oct 16, 2019
Hi! I am new to electronics...
May I ask if I can use a simple integrated circuits (IC) like AND/OR/OR/XOR/NOR etc... to make a sequential traffic lights just by clicking buttons or switches?
For example... The circuit will start up with the GREEN LED light up.. then if I click a button, the GREEN and YELLOW will light up.. then i release the button... then if I clicked a button again, the RED will only light up... then i release the button again.. then I clicked a button again, only the GREEN will light up just from the start and repeat...
Note: Is it also possible if I only use a single button??
I appreciate your answers! Thank you!!
danadak
Joined Mar 10, 2018
4,057
Yes to single button could sequence an array of lights.
A shift register or counter, decoder and button debounce circuit could accomplish this.
And Red, Green, Yellow leds along with current limit R for each led.
Is this a school project, homework ?
Regards, Dana.
30,823
You will need flip-flops and gates.
You can build flip-flops entirely from gates but that will make your project very complex.
This is a classic exercise in an introductory course in digital circuit design. You are attempting to build a finite-state machine, or a Mealy machine. You need to know about Karnaugh maps.
How much have you covered in your course so far?
Moderator edit: thread moved to Homework Help.
