How to use moderator power to a tool?
Sailboy42
Joined Oct 14, 2019
6
For STEM project I am making a heat cutter for foam and plexiglass using... a glow plug.
It’s being placed in a PVC pipe and it’s has to run for a few minutes. It will mostly likely be running at 12v 10amps.
I would like to install a power moderator as to not have it operate at its max temp 100% of time. But I don’t know what, or how to install a dimmer onto it. I’m thinking maybe like a dremel kind of thing. Any suggestions?
WBahn
Joined Mar 31, 2012
30,062
MOD NOTE: Thread moved from the Projects forum. Given the nature and purpose of a STEM project, Homework Help is a more appropriate forum.
danadak
Joined Mar 10, 2018
4,057
The power level/heat drives the size. You could always consider
fluid transport of heat, but the heat has to be sent somewhere.
Like a copper rod ending in a radiator at end of pipe. Or possibly
oil filled.....
I do not know what the thermal R is of PVC, thats a starting point
that will guide you to solutions. There are also finite element thermal
design software that can take objects and predict performance.
Regards, Dana.
