How to best drive 100W RGB LED - any suggestions for ICs?
-live wire-
Joined Dec 22, 2017
959
I have this 100W RGB LED, with each color having a max current of ~1A and a voltage of 30-35 Volts (except red which is ~25 V).
Here are my goals:
-I want to drive each color independently with a constant current of 1A at those voltages, as opposed to using a resistor or some other means of driving them.
-I want to be able to control it with the ESP-32, which I believe outputs 3.3V. So I need a circuit to convert it to a 5+V signal or an IC that takes 3.3V input.
-it should be a reasonably efficient circuit where only the LED needs active cooling, not any of the components controlling it
So here is where I need help. Is there an IC that can output those currents and voltages with just, maybe a 40-60V DC power supply and some passive components? Are there some that take 3.3V input? Also, it would need to be through-hole and not SMD because I'm not that good at soldering. I tried looking on mouser but I wasn't really sure if the ICs that were showing up would work, and I didn't know what some of the specifications meant.
Also, all of the constant current boards with those output currents and voltages were $20+ and bulky, and I don't want to spend $60 when there is an easy $5-10 DIY solution.
-live wire-
Joined Dec 22, 2017
959
Okay, thanks. I'll have to look into that more. What value inductor should I use, though? I didn't see anything in the datasheet.
-live wire-
Joined Dec 22, 2017
959
I'm confused, doesn't Vout vary based on the load if it's constant current, and also doesn't the constant current you want vary based on the input signal? upload_2019-10-8_13-34-51.png
Sensacell
Joined Jun 19, 2012
3,444
Near the end of the application note, they break down the calculations.
You will need to know the Vf of your LED.
Follow the reference design circuit as a start, calculate a new inductor for the LED Vf and supply voltage you are using.
The 2 critical things to get right are the value of Rcs and the inductor value and saturation current.
A Schottky diode is a must.
-live wire-
Joined Dec 22, 2017
959
Since it's supposed to be efficient, a 360 mOhm resistor for Rcs with a power rating of 3W is almost overkill, right? And I attached an image of the Vfs. The way the LEDs are configured its a 10s 3-4p grid for each color.71hyeAY2GdL._SL1000_.jpg
Also, is diode D a Zener or shottky diode? Looking at the image, It's hard to tell which way the lines are going and everything, and I haven't done much EE stuff in a little while.
Finally, is it wrong to assume that an 860uH inductor is the best here because on this graph for different Vfs it appears to have the highest efficiency?
Sensacell
Joined Jun 19, 2012
3,444
A 360 milliohm resistor with 1 amp flowing through it will dissipate 360 milliwatts. (I squared over R)
A 1/2 watt unit is sufficient.
Diode is a Schottky - see the reference circuit BOM.
Yes- it's naive to assume that an "860 Uh" inductor will produce the best efficiency.
Efficiency is about losses- which come from every part in the circuit.
The wrong inductor core material, too low saturation current rating, the wrong diode, etc - can all substantially reduce efficiency.
Build the reference circuit- a good place to start.
Making this work is relatively simple- making it efficient requires deep optimization, which requires a deep understanding of the circuit operation.
-live wire-
Joined Dec 22, 2017
959
I don't need 99% efficiency, just enough that the amount of heat is reasonable. But are you saying to even get 80-90% efficiency you have to understand it very well?
-live wire-
Joined Dec 22, 2017
959
If I'm driving a 100W LED, and it's 60-70% efficient, then where's the 50W of power being dissipated? In the IC? The inductor?
Papabravo
Joined Feb 24, 2006
21,225
In the LED itself. According to the datasheet you have 30-34 Volts at 2800-3500 mA which gives a range of 95-105 Watts. That is your power output. Your power input will be larger. If your efficiency is 60% then it will be 100/0.60 = 166.67 Watts. That difference will be consumed by everything except the LED, including the resistor, the inductor, and any IC's that are in the path between the input power and the LED.
