Logic circuit output for TC4071BP
Lemon_Foam
Joined Sep 18, 2017
39
I had built logic circuit as below:
When 3 sensor is on, it will give signal 1. Due to pull up resistor, the signal 1 will be reverse to 0. So, the signal input to the 2 logic gate will be 0. So, the signal Output A should be 0 too. But it always give me signal 1 at Output A when 3 sensor is turn on together
Is there any hidden concept behind this logic circuit? Since the output signal get was not expected.
danadak
Joined Mar 10, 2018
4,057
A pullup normally implies a "1" unless its buss connection is pulled
down by an open drain / open collector sensor output. If sensor is not
plugged in a logic "1" will be present because of the pullup. If sensor
plugged in, then whatever the sensor output is passed into the gate.
Whats is the sensor ? Part number/description ?
Regards, Dana.
WBahn
Joined Mar 31, 2012
30,086
"Due to pull up resistor, the signal 1 will be reverse to 0. "
This doesn't make any sense on the surface of it.
How will a pullup resistor reverse a signal 1 to 0?
What are the voltage levels for your signals? Is a logic 0 a voltage of 0 V (or something close to it) and a logic 1 a voltage of 12 V (or something close to it)?
Your schematic shows an OR gate and an AND gate, but claims both are a TC4071BP, which is a quad two-input OR gate.
Lemon_Foam
Joined Sep 18, 2017
39
Regards, Dana.
I use the EE-SX951-W1M Omron Sensor (Light on). The sensor circuit will always turn on (always 12V to pass into logic gate----Logic gate=1).
When i cut the thrubeam between transmitter and receiver, the sensor circuit will turn off (No voltage goes into logic gate----Logic gate=0).
Lemon_Foam
Joined Sep 18, 2017
39
Logic 0 is 0v, Logic 1 is 12V. I attach the pull up resistor illustration diagram and assume button as sensor and MCU as logic gate. If Button close (sensor on), Vcc goes into ground. If button open(Sensor off), Vcc goes into gate
danadak
Joined Mar 10, 2018
4,057
When sensor is on, output will go to logic "0", low voltage, or ~ 0V. Otherwise
it is at "1" or ~ 12V
Due to open collector output of sensor and pullup.
Incident light, no blocking of light, output transistor 1 on, output low, current
flows thru its load, output transistor 2 off, output high, no current thru its load.
Regards, Dana.
WBahn
Joined Mar 31, 2012
30,086
If the button is closed, Vcc does not go into ground -- but the input to the gate is pulled down to ground.
Are you declaring that the button being closed is the sensor somehow outputting a 1?
It sounds like if the sensor is ON, that the output of the sensor is LO (a logic zero), meaning that the sensor has an active-LO output. The pullup resistor is not somehow inverting the signal of the sensor, the output of the sensor is simply the opposite of the logical state of the sensor.
