Hi Guys , I am working on a kids small car project where I am using below spec DC motors.
Input voltage(V) 12
Retarder Reduction Ratio1:90
No Load Speed(RPM)180
No Load Current (mA)less than equal1100
Rated torque(kg.cm) 27.0 Kg.cm
Rated Speed(RPM)120
Rated Current(A)less than equal6.0
Max. Torque 90Kg.cm
Unload Current(A)20
Can you guys suggest what speed controller will work with the above motor or how do I choose which one will work best.
Here are few of them that I was looking into but I am not sure what to look for based on the DC motor spec.
https://www.aliexpress.com/item/328...hweb0_0,searchweb201602_10,searchweb201603_53
https://www.aliexpress.com/item/326...hweb0_0,searchweb201602_10,searchweb201603_53
AG
Input voltage(V) 12
Rated Speed(RPM)120
Max. Torque 90Kg.cm
Unload Current(A)20
AG
