This may be a long shot.
I have a high voltage switching ferrite transformer that has failed. Due to the construction of the transformer I could not retrieve all its windings. The only winding I could retrieve was the primary.
Is it possible to recalculate the secondary windings taking in consideration:
- cylindrical core area 80mm2
- operates at 50Khz
- ferrite Bsat ~0.3T
- primary (pin 4-5) has 30 turns. Is feed with +120VDC oscillates at 240v pk-pk
- feedback (pin 3-6) is feed with +2.3VDC oscillates at 4.5v pk-pk
- secondary A - (pin 9-10) oscillates at 2v pk-pk
- secondary B pin 1 ground
- secondary B pin 2 -120VDC rectified input
- secondary B pin 7 -220VDC rectified input
- secondary B pin 8 -2.7KV RMS supply to CRT
Regarding the current I can still retrieve the winding gauges.
- operates at 50Khz
