Hi All
I bought several 5v Fans (Brushless) for use as cooling for Raspberry Pi and other Mini-PCs.
All the fans that I bought use a relatively low current (relative to motors..), about 100-150mA maximum.
I would like to be able to control the speed of those fans, manually,
and so I searched eBay for the words motor speed.
2 results that repeat there quite often, are these:
The Red:
4.5-35v, 5A, 90W, 20KHz
https://www.ebay.com/itm/3V-35V-12V...Adjustable-Switch-LED-Fan-Dimmer/132270456321
The Black:
5-16v, 10A, ??W, ??KHz
https://www.ebay.com/itm/DC-5V-16V-...-dimming-10A-Ultra-Switch-Module/153325681507
All of them are good for 5v,
and all of them are way beyond the 150mA of current that I need.
So in that area, they will all be good.
Yet there might be some differences,
for example the red one has a big Electrolytic capacitor.
The black one does not have a capacitor,
or maybe there's an SMD capacitor there that is much smaller.
What effect does it have on the module's operation?
And any other thing that might help choosing between the 2?
If you can, looking at their components, tell which one is better, that would be really helpful.
Thank you very much
The Red:
The Black:
Thank you very much
