Not sure if this is the right place to post...
Looking to wire a standard home AC outlet power strip to a set of switches & leds. The end goal is to a button that when pressed resets/stops the power strip(being used to reset a modem/router) by using a momentary switch that acts as "kill switch"
However there is a bit more to the project. I would like to first have a set of toggle switches that must be turned on to allow the "kill switch" to work. Flipping the first toggle will activate an led, the 2nd toggle switch will activate a second led, as well as a blinking led, so you know the push button is ready to go. Then when the button is pressed, the power strip would loose power(only while the button is being pressed).
If this was a 12v project I could wire the switches and LED's. The new territory for me is running it all from a wall outlet, and momentarily cutting power to a power strip.
