Hello everyone and thank you in advance.
I'm working on my first 4 layers board (SMT). My layer stack is like this:
TOP - Signal (most important signals)
Ground plane
Power tracks
Bottom - Signals
The board is for a mixed system including sensitive analog electronics, a few digital ICs, a high current Amp (1A) and some ports for a display and buttons.
After long and careful reading of many books and online documents, I've reach the conclusion that the best way to make it work properly is to let a big ground plane for everything, providing that buttons and screens will be rarely used. However, I have read contradictory pieces of information about letting a second ground plane on the top layer. On one hand, making a "plane" in the copper-free space in the sensitive analog electronics could make it more robust against EMI noise. It can improve also crosstalk as there will be a ground track between adjacent noisy tracks (there aren't high-speed signals here, so don't expect any). On the other hand, it can lead to ground loops if I attach the polygon to the net. There is a possibility to connect the two planes only at one point, but it would worsen the ground loops.
To sum up, there are some alternatives and don't know which one is the best:
1- Let the TOP layer without a ground copper pour
2- Make the copper pour and connect it to the ground plane in only a point (not connect it to the ground pins of the components)
3- Make the copper pour and connect it to every ground pin and to every via to the ground plane
I'm thinking of a ground copper-pour only in the analog area.
Thank you again.
Ground plane
Power tracks
Bottom - Signals
Thank you again.
