Hello friends! I think the title is clear. I need to drive a 5V push/pull mini solenoid using a relay board (Not a micro-controller).
What would be the wiring and do I need any extra components to protect the board??? a diode? I was thinking to use the relay to close the negative wire of the 5V power supply then activate the solenoid for about 1 second. Is that safe? do I need a diode to protect the relay board?
This is the relay Board:
www.amazon.com/dp/B074MPWFF3/ref=cm_sw_r_sms_awdb_t1_0EPBDbH3Q65Q8
