Dryer runs, but no heat
juro
Joined Sep 28, 2018
65
narkeleptk
Joined Mar 11, 2019
558
Is this dryer on the line you just installed?Are you sure you have 240 coming in?
There are a few things that can make it not heat. Have you checked the element itself for continuity?
30,807
How old is the dryer?
There is a relay, temperature controller, and high temperature limit switch.
You may want to check those. The most likely fault is a break in the heater element itself. Look for this first. You can order and replace the element yourself. This is a reasonably straight forward task for the DIY person.
juro
Joined Sep 28, 2018
65
the line I installed is good. My oven heated up to 400F.
i would love to check the element for continuity, but i don't know where it is.
MaxHeadRoom
Joined Jul 18, 2013
28,686
Has this worked previously?
There is also two thermal limits that can cause a problem.
Strange:
The Neutral terminal also shows a link across to the earth ground on the input terminal strip, if so, this is a NO-NO. (at least in N.A.).!
Locate the BR and BK wires these are the heater.
Max.
juro
Joined Sep 28, 2018
65
from mid-90s.
i'm new to taking apart a dryer.
narkeleptk
Joined Mar 11, 2019
558
I just had to take my dryer apart of last weekend for mine I had to remove the top first and then I could tear down the front to get to the innards
MaxHeadRoom
Joined Jul 18, 2013
28,686
i don't know, i just bought it as is.
There's your first clue, most likely one of the thermal detect switches or the element itself, its a well known make so should be no problem getting parts, either local maybe, or on line.
Often the top lifts/hinges up, after releasing the front clips.
Max.
30,807
from mid-90s.
Everybody has to do something for the very first time.
If you are handy with a screw driver and a wrench, you can do it.
Yours looks similar to my dryer. I will have to compare model numbers.
30,807
First thing. Unplug the washer from the outlet.
Post a photo of what the plug looks like.
Next, go to the internet and find a video on how to remove the front panel. There should be two screws on the front and that will require a stubby phillips driver or you will have to tip the unit backwards to access the screws.
djsfantasi
Joined Apr 11, 2010
9,163
Or on my dryer, I had to release the console, so I could tilt it forward to clear the back. Then, a few (6) screws held the back in place. After releasing the back, I had full access to the control, motor, and heating element wiring. IMHO , you need to google YOUR DRYER MODEL, to gain access for testing purposes.
The first (and most important test) is that your heating elements have continuity. Then, work backwards. Does the control circuit work? Are the control circuits receiving power? And etc.. etc... etc...
