Anyone know how to do wireless power transfer at 24 volts and be able to slow stop and speed up a motor at 30 watt max?
maybe modify one of these:
Nice pictures!Anyone know how to do wireless power transfer at 24 volts and be able to slow stop and speed up a motor at 30 watt max?
Without another source of power, my answer is that you can’t with these modules.
First, you need 24V; these only transmit 5V of power. Just using that for an estimate, the efficiency is around 40%. Thus, to get 24V out, you’ll need 57V input.
Secondly, you want 30W. These modules only provide 2.5W of power. You’re more than 10x off.
You’ll be a lot better off starting from scratch.
You could use 15 of them in 5S3P to get 25V at 37.5 W, followed by a buck converter.
Why do you want wireless?
Bob
You cannot calculate the efficiency just using voltage. You must compare the power on both sides.The video uses a 9VDC battery to get that 3.5V. Again, about 40% efficient (calculated by dividing 3.5 by 9).
