I'd like to integrate a 10440 LiFePO4 (250mAh, 3.7v max, 2.0v min) into a design that can be charged from USB. I'm committing to LiFePO4 for the design as it seems to be the most environmentally friendly chemistry widely available at the moment.
Dev
- PMICs for Li-Ion are readily available for this application, but the charging voltage for most seem fixed at 4.2v, e.g. https://datasheet.lcsc.com/szlcsc/Shanghai-Belling-BL4054B-42TPRN_C83783.pdf . Can something like this be used with any sort of circuit to drop that voltage? If so, what would that look like? I'm unsure whether the charging curve for Li-Ion and LiFePO4 differ significantly so would welcome advice on this.
- Failing that, can you recommend a circuit/battery charging IC? Looking for minimal cost, performance not an issue.
Dev
