I'm attempting to replace an old stepper relay with a digital circuit. The stepper relay was being used to provide feedback to a machine tool CNC control as to which number tool was currently being used. There are 8 tools on this machine and the tools are mounted on an 8- sided turret. If Tool # 3 is finished with it's operation and the part program calls for Tool # 6 to be used next the turret will rotate three stations from #3 to # 6 and the CNC control will send three + 24 V pulses to the stepper relay to advance three steps. The output of the stepper relay provides feedback to the CNC that # 6 Tool is now ready for use.
The circuit I have attached is pretty basic and I'm asking for advise as to how to make it work. The tool turret is unidirectional, only goes in ascending order. The output of the UDN2981 has to remember what tool number was high when power to the CNC control is removed and then restored. The outputs from the UDN2981 have to be + 24 V. I plan to use the + 24 V pulse that is used to advance the stepper relay coil as the clock signal to the 4022. Also, I will tie the Clock Inhibit and Reset signals on the 4022 low.
I will greatly appreciate any helpful advice. Please see the attachment for the circuit. Thanks
