I have a 6V dc motor which I would like to get to run for 24 seconds and then to stop for 4 seconds and then to start again (and again).
The following is the pwm circuit that makes the motor run non-stop:
This first circuit works fine.
To make the motor start/stop I am using a second astable circuit:
taken from: https://www.electronics-tutorials.ws/waveforms/555_oscillator.html
I have calculated the C, R1 and R2 and this circuit also works fine with a LED. (It stays on for 24 seconds and off for 4 seconds).
Now when I try to combine the two circuits things get tricky.
I tried connecting the output of the second astable circuit (picture number 2) to pin 5 (control) and to pin 4 (reset) of the 555 from the first astable circuit.
(picture number 1)
I tried connecting the output to pin 8 (as the source).
I tried using a transistor in a forward emitter configuration on the output of the second astable circuit to amplify the signal back to the 6 volts I am using as a source..
I tried using a transistor as a switch, because I wanted to keep the low level at a low (so it wouldn't get amplified too much)
Whatever I tried the result is always the same. The circuit works fine with LEDS but not with a motor.
With a motor the LED that I kept as a reference starts blinking around 10 seconds and the 24 second stop never happens (and the motor doesn't stop either, of course)
Today I have tried a new approach. I combined the two outputs (from the two 555's) using a cd 4081 IC (an AND gate), and then I applied the new signal to the base of Q1 from circuit 1 (picture 1). Again the motor never stops and the reference LED starts to blink in about 10 seconds.
Becaus
e this happens with a delay I guessed it must be coming from the capacitor that is in the second circuit. I use a 100micro Farad capacitor.
I thought that maybe the motor draws too much current and the capacitor saturates in the first 10 seconds, so I tried putting a higher capacitor and using smaller resistors (to keep the charge/discharge times the same). The LED starts to blink even sooner than 10 seconds. I also tried a smaller capacitor.
The only things I haven't tried is using pull-up and pull-down resistors since not all the components are from the same logic families. Could this be the problem?
So my question can be summed up to the following: Why does a circuit that works fine with LEDs stop working (and start oscillating randomly) when at the output the load is a motor that draws a much larger current?
(picture number 1)
Becaus
