Dear readers,
I have an idea of a design which uses a LiPo battery which has to power a 12V led strip.
Right now, I have this boost converter to 12V:
https://www.olimex.com/Products/Breadboarding/BB-PWR-3608/resources/MT3608.pdf
12V is going to a mosfet which is controlled with PWM by a microcontroller to dim the LEDstrip.
This works well, I can controll the brightness of the ledstrip by varying the duty cycle as expected.
But I would like to improve the efficiency and reduce part count, because using a boost converter AND a mosfet seems a bit redundant.
I need the microcontroller anyway for other stuff...
I can't use lower voltage LEDs nor put more LiPo in series due to some constraints.
So I was thinking to control the boost converter enable pin with the microcontroller to directly switch the 12V output on/off with the PWM.
I think the boost converter should use a much higher frequency (1.2 MHz) than the PWM (2-10 kHZ) to have a stable 12V output and the PWM freq should be low enough so that the filter capacitor at the output of the boost converter does not smooth the PWM so much as to getting a voltage somewhere between 0-12V which would result in a difference in color because of the change in current and not being able to dim low enough do to the forward voltage of the LEDs.
I think this all sounds very logical and I think that i will be able to design this.
Does any of you see something i am missing?
Either a mistake in my thinking or a more simple solution like an off the shelf product that can do this?
Thank you in advance for any hints.
Best regards,
Zaishens
Best regards,
Zaishens
