Not sure if this is the right place to ask this questions, but the Mods can move the thread if needed.
My electric 220V 1.3kW lawn mower's asynchronous mono-phase AC motor burned out and I wanted to rewind it. While cutting and removing the copper winding I have counted the number of turns and made a drawing of the circuit diagram.
This is where I got stuck, because the diagram is not the standard single phase AC motor diagram what I expected. The main winding is made of two 0.6mm thick wires running in parallel (bifilar coil), which would be understandable if both terminal endings would be soldered together to form two coils in parallel, with the intent to increase the effective wire cross-section area (compared to a single 0.6mm diameter wire). In that case the two wires could be replaced with a single wire of about 0.85mm diameter.
However, the two coils are connected only at one point, at the ground. One wire of the other end goes to the AC phase input, and the other wire end goes to one terminal of the capacitor as shown on the attached diagram. In this setup the second wire of the main winding works as the secondary of a transformer feeding the starter coil through the capacitor, which does not make much sense to me. The motor did work for 6 years for about 1h every two weeks in the spring-autumn season. I still wonder if this is how the motor was designed, or rather a construction fault caused by a rookie worker. I am hesitant to rebuild the motor as it was unless someone can convince me that this is a correct desing and better than soldering both terminals of the main winding together in parallel.
My question is whether the diagram represents a properly desinged and constructed motor, or it is the result of a construction mistake?
Thanks for any input in advance.
