I'll start out by saying that I'm very inexperienced in the field, so forgive the simple nature of the inquiry.
I'm trying to build a little device that uses the following AV transmitter chips: TX6729
The problem is that the documentation sent to me by the seller is in Mandarin and I'm uncertain it is correct/suspect it's the pin designations for an earlier version of the chip (just from using a multimeter and checking which pins are connected).
My question is 2 part:
1) Does anyone have experience with this chip/can point me to a pin designation they know to be correct?
2) Again, I am very inexperienced when it comes to this so forgive the very basic question, but how could I see if the chip is actually working/transmitting? I don't have access to an oscilloscope and only have a multimeter.
Thank you very much for your help ahead of time!
