I'll be upfront it's a bit of a hack but I am splicing the xbox controller outputs into the transmitter the issue I am having is that the voltage output is out so I figured I would use some resistors and a diode to solve this problem.
I need a minimum voltage of 1.78 this is neutral anything less and the brake is activated
I need a maximum of 2.69v this is full throttle
I think I have come up with a circuit to do the job but I have no idea what to ask/look for when purchasing the parts, ie what resistors a small circuit board and a diode.. also could I swap the two resistors for two potentiometers to allow for a bit of trim? again what would I ask for over the counter?
The potentiometer on the diagram is the xbox trigger.
Many thanks in advance.
