Swear I had this working the other day. I made a change and now it stopped working. The TIP transistors are rated at like 80 watts, but since the coil drops voltage, the input voltage to the transistor should be 2V or so. I have 3.3mA going into the gate of the transistor. I've seen some schematics with a gate to ground resistor. Not sure if that is needed but I know I had one while it was working. I tried R1 = 1,000ohm and R2 = 10000ohm but looking back maybe I need R1 and R2 as a voltage divider so that the voltage input to the gate is dropped?
Anyway, I've burned up like 10 transistors (TIP120 and TIP102). I was trying variable tests from 41.6 to 46 volts yesterday to test how much I could drive the transistor. It seemed everything was working yesterday. I believe I increased the R1 resistor and that was what blew up my transistor.
Going back on what i said before, if the coil has voltage drop, the drain would be +2V or so for the transistor. The gate even with the resistor could in theory be higher voltage than drain depending on resistance in the transistor. Maybe this is why my transistors are blowing up? This is for a pinball machine and everyone says those transistors are valid to use. I might have to try some R1/R2 pairs and see if it works out better.
